I was in my local Goodwill thrift store this morning and spied a brightly colored little flashlight in a bin of other lights. It caught my eye because of it's bright safety pink color.
Further examination showed that it was a "PCa Ikelite". I got it for a horrific .99cents.
After I got home I googled the company and found out that it is a dive light used by scuba geeks all over the world. It has a "O" ring sealed body with a unique ring clamp that squeezes the big "O" ring for a pressure seal. Loading the 6 AA batteries is a task but once you get it loaded up it is solid water tight.
I turned it on and the little halogen bulb shot a very bright pencil thin beam! It's as bright as any of my maglites. Pretty small so I have decided to put it on a lavaliere around my neck for night walking. The little halogen bulb gets pretty hot on the glass lens but it's tolerable. Here are the specs for the light I got from the WWW.
Size 6.5 x 11cm ~ 2.5 x 4"
Intensity 7.2 watts
Beam Concentrated spot
Lamp Halogen 7.2 volt
Batteries 6 alkaline** "AA"
Burn time 2.5 hours
Weight in air 250g (0.6 lb) w/bat
Depth rating 90 m (300 feet)
The Ikelite website shows it sells for $39.00 There is also a 5 watt LED in the same body for $90.
I am most happy with this purchase!:twothumbs
Here's some pics.
Intensity 7.2 watts
Burn time 2.5 hours
Here's some pics.
