Ken J. Good
- Joined
- Nov 29, 2001
- Messages
- 590
Be glad to entertain the idea of doing a limited time CPF group buy on the Night Reaper if there is interest and it's Okay to do that on this forum.
Don't want to get blasted for running a fire sale here.
On a technical note, the internal electronics on the Night Reaper has gone and is going through changes to ensure the highest reliability we can given the application.
Some of the internal physical changes you will note:
The connection terminals between the battery and the electronics package are now vertical/spring loaded "towers" as opposed to leaf springs.
The battery sits against a internal shelf so that it can not apply any significant force against these towers when the light in used in a heavy weapon application. Not good to have a battery (1 lb. piston) moving back and forth against your electronics!
The entire electronics and platform the lamp sits on is now milled out of a solid piece of aluminum and press fit together. Then that whole assembly is press-fit into the searchlight. Gone are the relatively weak plastic molded parts and adjustments screws to center/focus the lamp.
The now tighter tolerances make for a no need to adjust lamp replacement process. We also eliminated the difficult to exchange lamp retention clips.
Now it's just a simple clamp that slides over the lamp assembly. 2 screws and you are done. The lamp will be perfectly centered and in in focus.
We will eliminate the 2 access plates that cover the toggle switches fairly soon. This will prevent the possibility of any water intrusion through that area and eliminate parts.
I suspect the what appears to be a better beam signature might be attributed to this now near perfect focus system. A few thousand's of an inch makes a difference.
Some of the changes incorporated into the Night Reaper are going to find their way into Polarion's handheld searchlight line.
It's akin to running a race car team. Good stuff is revealed when you are trying to push it so to speak.
Although the light outwardly appears to be the same from it's initial inception. It's not. Based on fairly extensive testing at this point, we have made a myriad of changes from front to back.
We went through a brutal round of testing at Aberdeen Proving Ground for the US Army and did fairly well to say the least. These things were soaked in water and salt-water, dropped on concrete, subjected to a wide range of temperatures and temperature shock scenarios, EMI signature determined etc. etc. A few things did show up, but virtually every one of those we were aware of prior to submission of our samples. We just did not have time to implement those changes prior to the test samples submission dates.
Everyone of those issues have been addressed in our latest production units.
We are now submitting units for testing for the SpecOps community.
https://www.fbo.gov/index?s=opportu...6b75a9602&tab=core&_cview=1CSFS&cck=1&au=&ck=
After meeting the program managers a couple of weeks ago, we are fairly optimistic that would should have Polarion's in the hands of that community fairly soon.
We are also in process of retrofitting quite a few US Military Vehicles with Night Reaper variants as well as in the hunt for some fairly substantial foreign opportunities.
2010 will be a wild ride for Polarion-USA, but I am having fun to say the least!
Back to our regularly scheduled programming...
