Popular hot wire comparison
Billy Ram
SC
FM09...m*g85...m*g458
Tower 200yds
in the dark
m*g85
FM09
m*g458
The FM09 is the smallest but not the weakest. About twice as bright as the m*g85 it packs a punch. The m*g85 isn't weak it's just keeping company with some serious lights.
Billy
Thanks for the pics Billy. :thumbsup:
The FM09 seems much stronger than the mag85, and the mag458 is just amazing.
Perhaps you could take some pics of wa1185 compared to fm1909, but with more exposure.
Cheers,
Dioni
Cheers,
Dioni
Agreed - nice setup for a great high-output beamshot comparison, but you need to increase the exposure. Since you used a 2 second in these, maybe increase it to 4 or 5 seconds?.. The Mag85 shot barely looks any different than the control shot, and based on my Mag85 I know it looks a lot brighter than that to the eye.
Absolutely love the green lights BTW..that 458 is just sick...:drool:
It seems like doing a longer exposure would just make the sky overexposed. Was it not completely night yet, or was there just a full moon or a lot of light pollution? Perhaps some beamshots with a dark background (not the sky in the background) would better show the intensity of the beams.
One other thing to try is only increasing the exposure slightly (maybe 3 seconds) but increasing the ISO to 200 instead of 100. This approach worked best for me in my last set of beamshots.
The conditions may not have been best for beam shots and the tower isn't very reflective. I still got a good comparison but the least powerful light didn't show up much. It may have been better to leave the 458 out and increase the exposure. Too much exposure with the 458 doesn't work out too well. I'm learning.
Billy
Billy
Exactly! :thumbsup:
yet, as Mjolnir said, there is also a big piece of sky in background.
Good effort Billy. Couple tips I found from talking to others and trial/error.
  • 1) Avoid full moon. Cloudy, 1/4 moon or less can be OK.
  • 2) Avoid ambient lighted areas. Some that won't interfere can be OK. Trial and Error.
  • 3) Always use camera tripod and table/stool/platform for light.
  • 4) Aim lights at same fixed object.
  • 5) Use camera setting that shows spill of least bright light.
  • 6) Start with these Manual Mode camera settings, but be willing to come back download image and see if it works. Always use at least 2 sec delayed to prevent movement, and let auto-focus work.
  • AWB - Daylight
  • ISO 100
  • F-Stop 3.2
  • 4-7 sec exposure (depending on output ranges tested)
  • If you can add labels to lights with item tested and camera settings, it makes a nice reference for people used to comparing to others they have seen. This gif is from shots I took a while back, but with labels it can still be understood.
  • AWB - Daylight
  • ISO 100
  • F-Stop 3.2
Very helpful information. My old Cyber-Shot DSC-P10 "with limited manual settings" may not be the best for beam shots but I'm getting it dialed in. The operator has limited experiance too and needs dialing in.
Thank you Lux
Billy
Ok folks I've tryed to get a better beam shots by finding better conditions and making some adjustments so here's the results. Tree is 75 yds.
I hope I don't get banned for posting too many junk photos.
Billy
Much better, but I think you should even go longer on exposure so you can see the spill of the Mag85. What were your settings on that series? Admittedly trying to use one setting for both Mag85 & 458 makes it harder to find the sweet spot, but a Mag85 should not look like a girlie-man's light either. Keep up the great work. :thumbsup:
Thanks for the excellent comparison shots. They show one reason why I gave up on the Mag 85 some years ago.
This camera doesn't allow a fixed exposure. It only allows adjustment and I have it set to the highest setting. The m*g85 is brighter than the picture represents.
I haven't given up on my m*g85. It's bright, has a long run time and is with me all the time.
Billy
When pitted against a 458, the Mag85 is a girlie-man's light.
Billy, thanks for posting those beamshots.
I'm surprized the batterys haven't went dead on the m*g458 with all these beam shots and getting set up. The Elite 1700s are really hanging in there.
You're quite welcome
Billy
Awesome shots!! Wow, this really illustrates the bump in output from the 1185 to the 1909 - easily doubled it..just amazing. To me the Mag09 looks almost 3 times as bright.. Yes the Mag85 shot is still quite a bit dimmer than in real life, but in these shots it is much easier to see the full beam pattern of each light which makes for a great comparison - very nice job! :clap:
BTW - anyone that would give up on the Mag85 is just nuts IMO.. who would turn down almost 60 minutes of runtime at 1300 lumens?? :shakehead Yes, the Mag458 output is absolutely sick, for the ~2 minutes you can let it run before the light melts down....
I hope you don't mind, but I took the liberty of making an animated Gif of your shots:
+1 for the HUGE progress in just two rounds of beamshots.
We all appreciate you sharing the first set. Determined to improve, the additional effort in location and composition for the 2nd set has created a very helpful trio of comparison pics.
It seems like the placement of those three lights and the camera were kept essentially in the exact same place for all 3 shots. In fact, the 1185 and 1909 shots look almost like they could be from a 2 mode light (the 458 is just too ridiculous for that). The edges of the spill for the first 2 lights seem to be in almost the exact same place. How did you get the lights aimed at almost the exact same spot each time?
It's interesting that the 64458 bulb does not throw as well as the other 2 lights, even with a larger reflector. It must not have a very impressive surface brightness, even with its high output. What cells are you using for the Mag85?
