cyberspyder
Regular 5-minute/24 hr epoxy will work right?
Thanks, Brendan
Thanks, Brendan
Do you know epoxy shrink? I don't know how much long would they cure/shrink but it's no good if it shrinks when it's hard. Components on your board may be tear off their pads. I have no data on this just a thought. It may not actually happen because lights below does not have the problem.
Some lights I know that has epoxy potted in their circuit board are Arc AAA, Arc LS First run, ARC4+, CMG Infinities. Surefire does not pot their circuit boards with epoxy, they coat them with a layer of silicone pcb coating.
I do have first-hand experience with epoxy shearing off components off ArcAAA boards. Since that I switched to RVT silicone for potting.
I've only used the smaller clear RTV silicone tubes.The big caulking tube you buy in home depot for sealing stuff? Or the Permatex ultra black/copper type?
