Power two light from one lithium battery
thedonald
I have a Lupine Wima front light with a Lupine 6.8Hh battery. I'd like to get a Dinotte 400R tail light and power it from the Lupine batter (using one battery to power two lights. The 400R is normally powered by a lithium battery and has a voltage cut off of 6v.
Do you see any problems with proceeding with this kind of setup?
:welcome:I don't know those systems, so there isn't enough information in your post to comment.
-Do both lights have a voltage range which matches the battery pack?
-if you connect the lights in parralel (each its own connection to the battery) will the battery be able to handle the drain?
-if one of the loads fluxuates (e.g. flashing light) the noise it produces in the circuit could be annoying (though I doubt damaging)
Hopefully some more CPF'ers familiar with the lights join in.
