roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
You only need 4 lights?!?! That is blasphemy talk around here!
Hahaha! I Agree! I'm close to 20 lights now.
An SR90 with an Aspheric Head would have to be ridiculously big in size.
It is ok to show someone what the Crelant can do with an Aspheric Head but really I could not see myself walking through the bush or anywhere for that matter without spill.
The Dereelight Aspheric is a "WOW" factor sort of thing but it should be used with other lights or rifle mounted with a scope.
The Crelant Aspheric image is at least twice the size of the Dereelight beam image but no brighter.
The Crelant 7G5 V2 already throws enough into the distance without the Aspheric Head and has good enough spill and that is how I will be using mine.
I still wish the strobe function of the Crelant was hidden and not part of the normal cycle of the modes!!
My favorite lights are still ITP EOS A3 Upgraded (3 light levels) for pocket use (EDC), the Klarus XT11 in my bag, Thrunite TN31 for serious lighting in my back pocket and then the biggies when really out in the middle of nowhere, the SR90 and TK70.
You only need about 4 lights to do all the tasks from pocket EDC to lighting the darkness like day big time, it is just finding the right ones to fit each usage need that is an ongoing search.
I have found mine for now.
I never went for the Xtar S1 production version because I tried it out and you can't get quickly to another light level after it has been preset without ramping to find it.
That's why I like the TN31, instant access to a good selection of light levels from moonlight to 1147 lumens via the magnetic ring and shorter body that still fits in my back pocket unlike a TK70 or SR90.
What do I do with all of the lights I picked up in my search along the way?
They are all in aluminium attache cases with foam cutouts around them all.
At least they are safe from serious harm.
Cheers
Long live my Thrunite TN31!!!!!
Cheers
Only issue I've had so far is that the "pill"
I guess, containing the LED and driver, started unscrewing itself from its metal body. This in turn led to the beam getting unfocused while using the collimator head. So, just hand screwed the sucker down and it's been fine ever since.
How does the Crelant 7G2CS compare with the 7G5 V2 (with 1 18650 cell)?
I like the 7G2CS more because of the smaller head, but I'm guessing the trade off is that I'll get less throw.
The 7G5V2 will still throw better than the 7G2CS. In fact, the 7G5V2 still throws better than the V9-T6 (I own both so i know) and the V9-T6 definitely out-performs the 7G2CS.
If you want a single 18650 light from Crelant with a capable throw, it would be better to consider the V9CS or the V9-T6. Go with the 7G2CS if you want a smaller headed light with a good enough throw.
