Narrowed it down to the PT EOS or the PT EOS Tactical. (I think)
Advice?
Before I pull the trigger I figured I would get opinions on the two and I’m leaning towards the EOS because of availability.
The Princeton Tec EOS tactical comes with a red, green, and blue filter. But is rated at 45 lumens. Also has a slightly different UI but that is not an issue.
The largest (only) problem with the EOS tactical is the fact there are no reviews on it and I have no idea what type of LED it uses.
These were the requirements that I had when narrowing it down to the two in order of importance.
Advice?
- Must be able to take lithium batteries. (AAA, AA or 123 ok; lighter & for cold)
- Must have low and high settings.
- Must be small and light.
- Must have good beam for headlight, balance for close up and distance.
- Good run time.
- Under $50. Lower the better as equipment gets lost sometimes.
- Prefer to have option to use red filter or have red LED. But not at the expense of the first 5. ( A red key fob led can fill this role if needed)
