The first one is a lighted inspection mirror with flexible arm. I used to use this thing frequently in my shop and around my place for all kinds of applications where a small lighted mirror is needed in awkward locations. The problem is it's made in china junk and I have had to do all kinds of band-aid fixes to keep it going, and even then it would not work reliably. It has now died a final death and I would dearly love to find a quality replacement for it.
I have found lighted inspection mirrors with led's that are mounted above the mirror and shine directly on the work, but they are not on a flex arm. I have also found adapters that hold a small mag light along with an inspection mirror but these simply shine the beam right at the mirror (instead of the work) and I have found that in many applications this just results in bright blind spot where you need to see. Also these too were not on a flex arm.
Any suggestions on a quality replacement for this would be appreciated.
The second item is a cheapy led light I received as a gift and it has turned out to be one of the most used lights around here. It is fairly compact, stable, and the head adjusts through a wide range up and down including the ability to point straight up, the batteries are located in the base. Last use was when putting in a fireplace insert and I was cleaning out the chimney area while laying on my back working above my head. I was wearing a dust mask and face shield as well as safety glasses so my headlight would not work in that instance. In addition, this light has a simple UI with low/high and a big button that can be used with a gloved hand. The head on this light is almost worn to the point where it will not hold position anymore and of course there is no adjustment on the plastic mechanism.
I bought a tripod type light from costco, I think it was stanley, but ended up returning it after two weeks of use because it was awkward to use, not very stable, and poorly made. I just didn't see it lasting very long under my use applications, and it was not nearly as fast and easy to use as the cheapy one.
Any ideas for a quality replacement for this light?
Thanks
Thanks
