Alin10123
Hey guys,
With all these new materials coming up for coating, i just had a few questions regarding different coatings. With regards to bare aluminum. I understand that if you hold onto a light long enough that's bare aluminum, it will start to tarnish and your hands will start to turn black. Is that only the case with aluminum?
What about Nickel? I know it's a lot harder material, but if a light is plated with nickel and you're touching the light all the time and holding it with your bare hands, does any of the material come off at all? onto your hands? Or is it a fairly solid coating?
What about with anodizing? If you anodize a light with either type 2 or HA3, when you touch it, does anything ever rub off of the light and onto your hands?
For example, if i pickup an iron pipe and then i put it down and i go to smell my hand; my hand will probably smell like iron and some of it would have gotten on me. Will the above materials do that?
What about materials such as stainless steel? titanium?
Thanks in advance
Thanks in advance
