Hi everyone:
I'm going to take the advice I got here a while back to purchase a set of Eneloop rechargeable batteries and a battery charger. I notice that some of the kits come with a C and D size adapter. I didn't realize that what this means is that one slips a AA battery into the C or D sleeve and presto, you can apparently use it in a device that uses C or D batteries.
I have some older 2D, 4D and 5D flashlights. I just called Maglight and they say as long as the output voltage is 3,6, and 7.5V respectively, it should work. I see this is simply 1.5V times the number of batteries. However the datasheet for the Eneloop AA battery says the nominal voltage is 1.2 V. Will the Eneloop's put out enough voltage for my Maglite D flashlights??
Thanks!
Thanks!
