Tony Hanna
Hopefully you guys can help me out here.
I'm looking for a decent light for work. Ideally I'd like to find something tough enough to survive in an industrial construction type environment (sealed against moisture, coal dust, fly ash, etc.) and inexpensive enough to not be a major concern if it gets stolen out of my dinner bucket or takes a 200' tumble off a scaffold. To that end, I've been looking at some of the Surefire clones available on Ebay. Particularly this one: Spiderfire L2 + 4x RCR123 + charger
Seems to me like a decent deal coming with 4 batteries and a charger. Not too sure about care and feeding of the unprotected Li-ions though. Any advice on that?
From searching around here it looks like the Spiderfire and Solarforce are the same light and I'm really liking the availability of different lamps, led drop-ins, tube extenders, and other accessories for the Solarforce. Assuming I can use them with the Spiderfire, it seems like it would be pretty easy to customize for the perfect balance of output, run time, and size. Also, I really enjoy tinkering with stuff, so it's attractive in that respect as well.
I guess I'd better get to the questions.
Safety first... What all is involved in safely using unprotected rcr123s? I don't want to kill the cells prematurely, but what I really want to avoid is and a house fire. If I have to sit and monitor voltage while they charge then that's fine, I just need to know what voltage to look for. I'll probably buy some protected batteries for it in the future but I'd like to use the ones that come with it for now.
Second, is this combo worth the money or could I get a better price buying the light and getting the batteries and charger (or everything) somewhere else?
Third, how bright is this going to be in it's stock configuration? As a point of reference, the brightest light I own is a 2AA Eveready Industrial with the battery rails filed to accept 3 cr123s overdriving a kpr112.
Fourth, how much of an advantage would it be to switch to an led at some point in the future? I guess I'm not sure if an led is better for run time, output or if an improvement in both can be had at the same time.
Any answers or advice would be appreciated.
Thanks,
Tony
Thanks,
Tony
