Quick question on dereelight regulatio....
purezero
I searched a good bit and could not find anything. I know the DBS v3 is regulated. I have been using mine at work and it seems to be getting dimmer after a little use. However, It is also very cold outside (5-15 deg F) and that could also play a part.
Running the R2 single mode pill and One 18650, the light will be constant and just shut off, right? Will the cold affect its performance at all?
Thanks,
Ok, than it sounds like a problem from your 18650, they dont like temperature under 32°F (0°C)
Well damn. Any other options for cold weather? I am using AW 18650's right now.
No problem with mine in cold weather, Just checked voltage and amperage straight from fridge and even freezer with little problem. My light likes cold temps infact as it helps keep the LED cool.
