IsaacHayes
Pitbull & Planterz: both are LuxIII's, both on o-sinks. Actually lux1's can be driven at 700ma before increase in power doesn't get you much extra light. The luxIII advantage is when you go to higher currents than 700ma. We were doing this before the luxIII came out and then compared them.
GarageBoy: You wire them in parallel. So connect both grounds, both postive in's, both led +, and both led -. Reason I did this is my input voltage was too low to have a single driver boost the full ~1000ma by itself. So by using two drivers, the load on them is reduced and they can run in regulation. Click here to read about the cyan mod.
