batmanacw
Re: force setting?
You need to disable reprogramming. It details it in the manual, but doesn't really explain it well. You have to use the programming menu. Option 6 if I remember.
I enabled it to change the settings. Now disable it. Problem solved.
Although you aren't likely to accidently reprogram your light, it isn't that difficult to accidentally change your settings. All it takes is a click-click-press to increase the light level of your current setting. But a quick click-click-press again will decrease it. So it isn't as if you will have a hard time putting it back the way you liked it.
I really like how easy it is to change the light levels because I can easily change it while I am using it.
