Rzr800
I have readily admitted that I know absolutely nothing about flashlights on several occasions and appreciate my 'newbie' status...yet please help me understand if there is some kind of 'tradeoff' in the following specs:
http://www.cpfmarketplace.com/mp/showthread.php?t=168357
Tiablo A9 and A8 LED FLASHLIGHT with CREE Q5 wc bin, limited edition!
Beside the new "Super Reflector Technology", RaidFire® is also proud of the regulated Light Engine E3TM circuit used in this light. The technically advanced regulated circuit is designed for one single Li-ion battery, has excellent efficiency and regulating capacity. When under Max Output, the Light Engine E3TM of the SpearTM will be able to produce 1.16A invariable current to the LED, which allows one Q5 CREE LED to throw and amazing light output of 250 lumens. At this time, Light Engine E3TM draws a 1.29A current from battery on average, with an actual circuit efficiency reaching about 90%. By using such a high efficiency circuit, RaidFire® SpearTM is able to maintain a constant maximum output for up to 110 minutes when using one 2400mAH 18650 Li-ion battery
Output & Runtime
Maximum Output 250 lumens, for about 110 minutes (with brightness declines to 50%)
Minimum Output 5 lumens, for about 200 hours (with brightness declines to 50%)
Question: Which Tiablo light stands to be the one we would be comparing the Raidfire Spear to when it is released?
Output & Runtime
With the follow-up question being...are the 5 lumens at this uberlong run-time designed to compete against this other light for what specific duties in the targeted market?
I'm not knocking either light and have bought the Spear because I felt that the price was right and it just plain looks good ...yet am I indeed missing something here?
