I started off here on CPF by modding my G2 to have a clickie. See Sigline Link for the history. In my early exuberance I didn't realize the differences in reverse and forward motion switches. For a while now I've been putting off this little project but seeing someone else ask the question has pushed me into forward action.
Here is a picture of the switch as I have modded it to date. The ground tab sits in a gap cut into the threads of the plastic switch case. I'm not sure this is a true reverse clickie or an incorrectly designed Forward Clickie.
Now when taken apart I have from left to right:
Switch Case
Spring
Spring Contact
Bottom Plate w/ Click Spring
Ground Contact
Metal click disk
2 parts of the ratcheting clicker
Top plate
I failed to line up the parts correctly so I PS'ed the image to show that the 2 springs rest above the click disk. The end result is to position the contacts below the click disk. To do this some of the bottom plate will be removed and spacers will be added.
The green outlined areas of the bottom plate are to be removed. The 2 contacts in this image are in their original place. In their place I will put a plastic ring and put the contacts flush to the bottom plate after removing the pedestals they rest on.
I have illustrated this in the picture above. I'm not yet sure about the (yellow)pins I've shown going thru the (periwinkle blue)spacers as the top plate pins may still work
If any one has any input feel free to speak up. I'll start dremeling into this later
And does anyone else have a clickie reverse or forward like this one?
Switch Case
Spring
Spring Contact
Ground Contact
Metal click disk
Top plate
