Hi,
Having spent some time debating between buying a DiNotte tail light (£70, no fuss, and a neat little package) and building my own (probably costing not so much less, all in, and unavoidably an ugly duckling) I've obviously decided to make my own!
My main design considerations are as follows:
1) Bright (naturally!)
2) Wide viewing angle
3) Flashing
4) Lightweight
5) Min battery life of approx 1 hour
My plan is to use a red-orange Luxeon III with a flare lens from L2 Optics. This lens will effectively give me 180 degree horizontal visability, with fairly little leakage up or down. Two questions about these lenses:
1) They sound so ideal for rear lights, I can't believe everyone isn't using them. Have I missed something?
2) It isn't clear from the datasheet whether they can be used with a star, or just with an emitter. They're described as suitable for use with "all emitters" and mount driectly to the PCB, so I assume I can use them with a star. Does anyone know for sure?
I'm planning to drive it using rechargeable batteries 4 AAs, or a pair of CR123s. To keep things as light as possible, I'd like to go the rechargeable CR123 route, The light is just for commuting and recharging every day at work is no great hassle. Will CR123s meet my needs? Is it a choice I'll kick myself for later on?
In a slight departure, I was considering using a regular lens (i.e. not a flare) but covering it with some kind of 3D diffuser. If you can imagine cutting a pingpong ball (or something less meltable) in half and putting it over the lens, that's pretty much it. Is this crazy talk?
The rationale behind the ping pong ball idea is that I don't actually need the light to project at all. All I really want is a very bright spot on the bike that is visable from any angle. I imagine the ball being fairly uniformly bright from any angle, whereas a lens would dazzle people directly behind me and underwhelm anyone looking at it off-centre.
Finally, what about drivers? 1A drivers are easily had, but looking at the Luxeon III datasheet (page 11, second graph down) it looks like I'll be sacrificing 23% of the red-orange star's brighness for driving it under the full 1.4A. Having said that, I've had no luck finding a 1.4A driver. Alternatively, is it worth forgetting about the driver and just driving it directly (especially since I can recharge every day)? Using a driver does have the advantage that I can use a built-in function for flashing the LED.
Any comments/thoughts are very welcome before I start buying parts. I'd also appreciate recommendations for a suitable driver (especially one easily obtainable from the UK!)
Many thanks,
P
3) Flashing
4) Lightweight
Many thanks,
P
