Well, here it is in all its glory. 4x Rebel Red-Orange 50's on a Cree mount!
They float together when you reflow. You can't space them even if you wanted to. 200lumens @350mA, and putting it side-by-side with a red Lamnia BL-2000, this is slightly brighter at a fraction of the power.
4W, not really asking too much of the mounting especially considering the device-to-Star interface is solder.
Reflow with a heat gun to the bottom.
I had one of the 4x in series blow up... I was having trouble with the test lead though, I was having trouble adjusting the power supply and I think I had it set too high and it gave a pulse from the supply's output cap before the current limit kicked in. Or maybe the reflow didn't work under the pad, because that first time I was using the toaster oven and maybe there was a problem, I'm not sure. The remaining devices seem ok.
I rearranged it so there are two 2x series strings in parallel and turning up to 700mA. They don't turn on at the same time, and at low power one side shines much brighter. Still, once I turn the power up they look pretty equal. In any case, the devices are each rated up to 700mA so even they don't share well it's still within the limits.
Actually when I still had them in series, I tried it at 350mA and 700mA with the BL2000 on a fixed current beside it for reference. Honestly, not a lot of intensity difference when doubling the current, in this configuration apparently the increased die temp is hurting nearly as much as the extra current is helping.
