Recoating a reflector
jason9987
Dutchess Couty, NY
Can any one here recoat a reflector that has had its reflective finish ruined, I have an HDS U60 and I tried cleaning the refector, then after it looked foggy found out its a very delicate coating and you have to be careful when cleaning it. Well doe anyone have the capability to do this or know someone or somewhere I can get it done. Thanks in advance
This has been asked before, and while there was a specialty chrome spray, I think the basic answer is it needs to be resurfaced professionally.
Send it to Carley Reflectors/Lamps. You'll get it back in about 2 years the way they run.
Thank you very much LuxLuthor it sounds like Carley will be able to do it for a reasonable price, I'm waiting on them to email me a quote but it sounds good.
Some years ago an auto body shop (the type that does "bling bling" custom work) near me had a mirror surfacing machine. They chromed? aluminized? some plastic buttons for me and it looked great. I don't know the optical properties of the material they used but it was only $20 for a handful of plastic bits.
what about extreme fine polishing of aluminum or steel reflectors? i can polish aluminin and steel to a mirror finish.... is this viable for reflectors?
It depends. If you are patient and carefull enough you can get pretty close to a mirror finish polishing aluminium. Recoating/plating or vacuum metal coating are the best, but I have polished the nickel off of a few McFloods to good effect. I get more light out of the polished version than the original. But, I'm going for a flood beam, things might be very different if the reflector was optimized for throw. You need to make a tool that fits the shape of the reflector, I used plaster cast directly in the reflector with a release agent. Look at it this way, the HDS reflector is ruined in it's current state. What have you got to lose but time by polishing it?
I tried that once on a Nuwai Q3. There was definitely more light
coming out of the original coated reflector, even though I polished the
Al. in the other one to a nice shine.
