embeddedmatt
- Joined
- Oct 20, 2010
- Messages
- 2
I'm currently using a Princeton Tec Amp flashlight for my work in state defense force. The light is fine and it runs on AA batteries but it has an annoying habit of turning itself on and running down its batteries. Also it doesn't have a red filter. I'm looking for a new primary light so I can move the Princeton Tec to backup.
I have filled out the form (see below) but I'll briefly say that I need something that is relatively small and light because the amount of gear I already have to carry is outrageous. Use will be night map reading, search and rescue, bag searches, night traffic control, and basic camping use. If the stuff really hits the fan (say, a riot), it could also see defensive use but this is not a primary consideration. Primarily black or OD color preferred.
Finally, it needs to be good for a 3 day mission without access to anything except one set of spare AA batteries. In order to limit weight and bulk, all my electronics (radios, GPS, lights) need to be AA compatible. And nothing fancy either, in a disaster I can't rely on being able to get any think other than regular alkaline batteries.
Thanks for your help. This is a great forum.
I will be mail-ordering or buying online.
2) Budget:
Less than $100. (not a hard limit)
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Every day carry medium (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I would prefer to buy a light from a traditional mass producing manufacturer that is ready to go out of the box, but I would consider getting a light that is pieced together.
7) What battery type do you want to use?
Strong preference for AA alkaline compatibility.
8) How much genuine out the front (OTF) light do you want/need?
I want to navigate a dark room or read a map (0-10 lumens). - AND -
I want to walk around an unlit rural area (50-150 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Less than 1 yard/meter (reading, other close work)
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
I don’t know.
13) User Interface (UI) and mode selection.
At least two levels would be nice. Strobe would be nice but not required.
14)Material/Finish/Coating
I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Red filter (for preserving night vision).
2) Budget:
3) Format:
6) Manufacturer:
I don’t know.
I don’t know.
