I've been searching hard for such a light, but haven't been able to find any that meets my criteria. Hence throwing the question to the CPF community. Maybe someone has a recommendation that I don't know of.
Personally I've come to the conclusion such a light does not exist - after months of searching I've still not found any.
Light Criteria
1. Bombproof
Doesn't need to be on the level of HDS and Barbolight, but it has to be better or equal to the Fenix TK/TA series.
I'm wary of Olight and Jetbeam after multiple failures from their various offerings, but if no other options present themselves then I will take a hard look at them.
2. Waterproof
Well, a high priority. I'd like it to be of HDS standard (20m), but I'm willing to accept Fenix's IPX8
N.B. Fenix's IPX8 = 1.5m for 1h, but I've personally tested it to be much deeper and longer.
I would like the dealer to state that it is either 'waterproof' or 'weatherproof to xx metres'. If the dealer doesn't state that, the light is out of this selection process.
One exception I will make is for certain lights (Surefire M2 comes to mind) that have a proven track record (proven = multiple sources, not 1 or 2 people chiming in saying their light is waterproof).
3. 150+ lumens
150+ lumens OTF minimum. If not OTF, then it needs to be 200+ lumens, to take into account light loss from reflector, glass etc.
Also consider that the light output may drop after start up time. 4sevens' Quarks come to mind, even though they are rated OTF for their XP-G R5 models (Their limited run XP-G S2 models are rated differently).
4. Takes RCR123s.
5. Small size, single cell.
Within 4.5 inches, CR123 based.
6. Would prefer TIR
Well, feel free to recommend a reflector based flashlight here, but I've a feeling that the body size requirements in point 5 will eliminate any reflector based contenders.
Well, that's about it. I've been looking hard at the Surefire E1B. Like the TIR optics, and the clip and size look just about right. Sadly, it fails my RCR123 test and waterproof test (I generally consider all Surefire 'E' and 'A2' lines not waterproof with the exception of the LX2 which is waterproof to 1m).
How far do I want it to throw? Use the Surefire E1B as a benchmark.
Light Criteria
1. Bombproof
2. Waterproof
3. 150+ lumens
4. Takes RCR123s.
6. Would prefer TIR
