Johnno
I have an EagTac D25LC2 and a Nitecore MH10, both with a CREE XM-L2 U2 LED and use one 18650 3400 mAh cell. I love both but use the EagTac every single day for work - can't beat it. I think both fit the bill for what you're looking for.
Neither of your recommendations offer sub-Lumen modes (I.E. very low output modes that are under a Lumen) and can be very useful in certain situations. They are also much longer and heavier lights making them far less pocketable for EDC use.
The Zebralight SC64c (18650 Neutral White High CRI) for example, is only 3.64 inch (92.5 mm) in length and only weighs 1.3 oz (38 gram) without a battery. It also supports a much wider range of modes (as well as programmable ones), has a very nice high CRI output (93-95), and goes all the way from 900 Lumens down to 0.05 Lumens.
While the others are good lights, the Zebralight is in an entirely different class. (Think Porsche 911 instead of Toyota Camry.). Pick one up and find out for yourself. They are pretty amazing lights. There is a reason they are talked about and recommended so often here.
