akula88
1. [ Circuits ] I got a lazy New Year's Day afternoon to burn and went on to play with half-dead CR123s. I got three BattStns from my Mag/V4T/DD and loaded them into a Balrog-3 body. I tested them repeated both on a KL1/SWAK/700 and with Aleph3/TWOK/DB917. KL1 puts out a 'moon' mode brightness, while the A3 still has a very good and bright beam -- more like a 10-ohm low output. Why is there a big difference? Is the A3/DB now in direct drive? What is KL1's circuit doing? Boosting or on Buck? Overall voltage was 8.4volts for the 3, but I don't know how much capacity is left.
2. [ Wiz2 and DB] So if KL1 is relatively inefficient, how far can Wiz2 go in the above situation. I know the Wiz2 is limited only up to 6v, but assuming only 2 cells were used? How much heat does Wiz2 produce compared with Downboy, assuming both are rated at 700ma?
3. [ Reflectors ] I loaded 2xPila150's on the MagV4T and found that it's brighter that my L4. I like the large hotspot of the Mag and hates the dispersed pattern of the L4. Would an Aleph-3 with a LuxV/LE have similar beam pattern as the Mag; and the L4 would be similar of Aleph-2
4. [ LuxV ] What would be my maximum LuxV current to produce a long running and not a hotstick light? The Mag/V4T/DD is quite hot after about 5 minutes of continuous use -- and it has a large tube and head/heatsink.
Please share with me some insights and enlightenment. Currently, I'm inclined that my KL1 needs replacement with a Wiz2-based Lux3 rated at 600ma, while the L4 with a LuxV-DB1000.
