Maybe he took a cue from Osram and used laser ablation.
Did you try ethanol or methanol?
What reflective surface? There's no functional reflective surface in/on an automotive halogen bulb. Osram is using the laser to burn a specifically-shaped window in the blue coating.I think it that use it was used on the reflective surface for dimensional accuracy.
It will probably take supervillain money to get one up to the task, it definitely won't be the kind you find on DealExtreme. That kind of power surely doesn't come cheap. (Probably won't need One. Million. Dollars. either.)Sounds like I need to invest in some frikkin La-Zers
Probably not, and it's not worth the groundwater contamination and potential health effects playing with it.I wonder if TCE can do the job
