Re: Removing bulb holder on 2 AAA Mag..
Ok, now that was easy enough. Pried with a screwdriver and it popped right off. It's still good but I can't use it on this light anymore. I had to cut the end off the tube to get the batteries to reach the new head. An LOD CE now sits on the 2 aaa Mag body.
It's not the best, but it works! Here's what I did....
After removing the bulb holder, I cut the end off back-to and keeping about the last 2 threads. I then had to grind down the body about a 1/2in. from the end in order for it to fit inside the LOD head. The barrel is too big and of course the threads don't match. After it would fit inside the LOD head, I cleaned up the rough edges a bit and wrapped some Teflon tape around it, just enough of it so that it actually threaded onto the head. It's not real secure but good enough to play with. :laughing:
To change modes I have to use the tailcap. The head just doesn't match up well enough for that. About a turn, turn and a half removes battery contact to turn it Off.
I'm using 2 NiMh's and of course, it's pretty bright. I only spent about 1/2 hr. on this.
I would like to see Fenix come out with a 2aaa version of this or a 3d party produce the body. I'm aware of the 10440 3.7v Li-lon usage in the LOD CE, this would just be another option. :thumbsup:
You like?
[EDIT] Thanks for the replies....
