I am looking for a replacement digital regulator circuit board for the www.dealextreme.com/details.dx/sku.17401 [URL="http://www.dealextreme.com/details.dx/sku.17401"] [/URL]. the one I received worked for less than one hour. I was still on the same battery. it started flickering, so I checked the battery. it was good. I replaced it with a new on just incase. then found the Reflector was a little loose. after I tightened the reflector end, the light went OUT. I checked the connections and and found the RED wire was broke coming from the regulator going to the LED. after soldering the wire i thought i would be back in business. But there is no voltage going to the LED. so if any one has a good idea of a replacement regulator please let me know. all the ones on the DX site are smaller than the one that fits into my PILL(21mm). is there any idea of how to use the smaller(14-17mm) Regulated Circuit Board.
