rizky_p
Has anyone measured a total resistances on Standard Mag 2D?
Thanks.
Thanks.
Thanks.
With an incan bulb, it means three things:OK, so what does this mean? The light will run HOT? The efficiency is reduced causing batteries to run down faster?
1) The extra resistance reduces the current, so the batteries run down slower
2) The reduced current means the bulb runs dimmer
3) A bit of power is wasted in overcoming the circuit resistance
Now in certain cases, if you are overdriving the bulb right to the limit, the circuit resistance might be all that saves you from an instaflash; so reducing the resistance isn't always a good thing...![]()
With an incan bulb, then yes, lowering resistance will decrease the run time.Mr happy, are you saying that lowering resistance will decrease run time?
And if that is true, is it due to the bulb drawing more power from the relatively higher voltage?
You may want to specify what components you will be using in your standard 2D Mag. Obviously, the switch & spring are stock, but as you can see there are variable amounts of resistance in battery holder/pack, bulb holder. Then there are resistance variations if you use a KIU with various ways of connecting bulb holder wires, or AW's D Driver, etc.
I have, but like a fool I don't remember where I wrote it down.
I was using some cheap 3AA-1D adapters with Eneloops, and from memory the results were something like this:
Internal resistance of cells 6 x 50 m = 300 m (m = milliohm)
Resistance of battery holders = 2 x 150 m = 300 m
Combined resistance of Mag springs, switch, etc. = 400 m
Total circuit resistance = 300 m + 300 m + 400 m = 1 ohm.
The 400 milliohms might not be exact, I am going from memory there, but it's in the ballpark. There are various steel parts in the current path of a Mag and I think these account for most of the resistance. I believe the main contributors are the tail spring and the long thin spring in the bulb tower. Secondary contributors are the steel strip on the outside of the bulb focus slider and the switch contacts.That is ALOT of resistance..!
You can bypass many of the steel parts with copper wire to reduce the resistance.
Actually I have found it very difficult to get accurate resistance measurements in the fractional ohm range with a DMM. The most accurate solution I've found, if you can set it up, is to pass a known current like 1 amp through the part to be measured and then measure the voltage drop with the millivolt setting on the meter. If you have two meters you can measure the current and voltage simultaneously.Yes i just did, Dont have a decent DMM to measure total resistance to confirm reduction after the mod. :mecry:
Yes, I typically just use a bulb of some sort in the circuit to limit the current to an amp or two.Nice idea, in fact i have two DMMs i might try it. I assume some load is required?
