degarb
Resistor question:
If I can't visualize in my head, with analogy to water, I have a difficult time understanding. So, I am a little fuzzy on one fundamental, maybe.
I always assume, that when you cut current with a resistor then you cut battery usage. This is based on my experience with a task-light based on the Lux I, running it straight for 12 hours with a 3 AA Garrity with resistors from ¼ power to %100 power (depending on task), and she was still pumping usefully on full power (12 foot unsanded trim boards, at 11 or 12 hour out).
But people keep saying a resistor burns power. I ask what they mean and to quantify it, but no one can respond. So, I am assuming this loss in power burned by resistor would be equal to current drop times voltage drop usually needed to run at lower current without resistor, if there were no thing called a forward voltage.
Or am I wrong, and a 2500 MAh 3 AA pack cut from 500 milliamp to 250 milliamp would not get double runtime (from 5 hour to 10 hour)? Would 4 AA cut to 250 milliamps not get 10 hours too?
I wonder because my tests yesterday, I saw a 3 AA pack drop from a peak of 500 milliamp to 300 milliamp in only 3 hours, driven at 300 to 250 milliamps, driving a Rebel 80. Is this quick current drop normal for these rechargeables? So as a result of this test, I am thinking of driving with 4 AA's, so I can more consistently manually regulate it to 250 or 300 milliamps over the 8 to 10 hours of use, by edging up the variable resistor every so often.
