Miciobigio
Review : \"Dialogue on the Aleph System\" *PICS*
Simplicio : What is that ?
Marco : It's a flashlight , a torch , it makes light in the dark.
S : What's his name ?
M : His name is "Aleph1" You can see the laser engraved logo onto the head , it's built by McGizmo
S : /ubbthreads/images/graemlins/cool.gif i want it ! What i have to do ?
M : you have 2 options
A) kill me and take this /ubbthreads/images/graemlins/frown.gif
B) read HERE and send an email to McGizmo /ubbthreads/images/graemlins/bowdown.gif
i suggest you option B) /ubbthreads/images/graemlins/grin.gif
S: Can you describe it to me ?
M: Yes , sure.This torch has a 5W led ( but you can choose a 3W led if you want a super-thrower ) and as for the driver has a Badboy 750mA so i can use it with a single 123 or with a Li-ion rech. or with 2x123 batts and also with 2xCR2 batts.
S : How is that possible ?
M : because this torch has 3 different power packs
The smaller one is for a single 123 batt.
The middle size one ( called 17500 ) is for the li-ion rech. Pila or Copia and take also 2xCR2 batts !
The longer one is for 2x123 batts but i use it also with my 17670 Li-ion rech. they fits perfect !
S : can i use my old E2 battery tube ?
M : sure, you can use E2/E2E/E2D/E2O/L4 or every compatible ( UBH , Balrog's ) SF E-series tubes.
S : and the tailswitch ?
M : the Aleph tailswitch is a 2 stage switch ( remember the SF-L1 ? ) , press 1 stage , press more full power OR twist first stage, twist more, full power.
S : can i use instead the SF-Z57 click-switch ?
M : yes you can, and you can also use all the other SF E-series tail switch.
S : but the SF tail switch has that glowing capsule that is so cool in the dark ?
M : No, but i think that you can try to ask Surfire to make a special E2E-glowing-tailcap just for you.
S : what do you think of this torch ?
M : It's simple , it's the best i own , you can see some beamshots and you can see that also with the small power pack , using only one 123 batt. , it's outstanding , i like the big hotspot of the 5Watt-led and the bright side spill.
The finish is top notch , it seems a SF-project , the modularity is the real bonus , i could not be more happy. (but my english is so bad that i esitate to write all the good tinks i feel of the Aleph )
Aleph1 5w vs E2 /ubbthreads/images/graemlins/grin.gif
Aleph1 5W on low vs Arc AAA
Aleph1 5w using one 123 (3Volt) vs Arc-LSHP Lux3-Tbin 670 ma 17mm reflector
