Yes, I use that battery in my BitZ and it works just fine. I don't believe the BitZ has any sort of low-voltage warning built-in so you really are on your own as far as the light draining your rechargeables. So far I've managed to drain a primary 123 down to 2.8V or less before the light started acting a little strange -- buck boost failed to get into high mode, etc. So you probably don't want to drain your rechargeables that low or you'll end up shortening their lifespan.Will the BitZ work with the Ultrafire 3.6V 880mah Protected Li-Ion Rechargeable Battery?
Sorry for my ignorance... is there any means of BitZ?
Korean word of light (not flashlight) is bitz.
Those UF 880's are one of the longest RCR I've seen. I'd go for the AW or yellow Battery Station ones. I don't think the UF Protected is a good choice for this light.
The Novatac 120PWhat other lights out there are worthy competitors to the BitZ right now? I was thinking about the Aeon, notwithstanding its smaller size. What else should I consider as I evaluate the BitZ?
Got the Novatac. Great light, but it is quite a bit bigger, isn't it.
Darn your pictures, Pat36! I must have one. But first, low low needs to be integrated into the main UI...
The twisty action works well so getting to the LowLow is easy. I think its a stellar light.
