The E2 is the Eagle 2 a completely different light with different specs including 700 lumens. Which of course begs why the Explorer if this similiar light is that much brighter.
Can anyone recommend where to purchase the E2? Thanks
How does the total output of the WE P7 or MC-E compare to a single die light on high? I am toying with getting a P7 or MC-E head for my Sniper.
That's ok, because I'm after the wider beam as well as the increased output.
My WE Q5 module, the 3.7-6V R2 hi/lo model, says it's regulated, but as far as I can tell, it's actually not really a flat regulation. The current draw drops as the runtime goes along, instead of increasing like it should. Are the MC-E models the same?
I asked my local dealer who also has the new specs about that. They did indeed increase the performance, he said they improoved LED and drivers, so it probably is a higher flux bin than before.All of a sudden the Wolf-eyes websight now lists the MC-Explorer @ 700 lumens, and the runtime is down to 45 minutes. Did they up the performance, or just the specs???
Default mode: Maximum brightness (100%) -> 30% brightness ->lowest brightness (2%)
Moving it around a bit already suffices, as the frequency is rather low. My scientific method of using a DMM says 165 Hz for both Med and Low.PWM:
Using my highly scientific method of pointing the light into a fan, I detected PWM in use on medium and low.
The WE website lists a MC-Explorer and a MC-E2. They look to have the same specs. Is there a difference? Also PCtactical has Explorers with different LEDs/lumins what is with that?
It is there on the Wolf-Eyes website and has been briefly covered in this thread a few posts before.As for different lumen Explorers, I couldn't find that. They all seem to be 580.
