PROGRAM OPTIONS.
RGB-PRO has two distinct program modes. Architectural and FX. In FX mode all programs are available for selection with the program button, but in Architectural mode the flashy effects are locked out and only the dignified effects can be selected.
To change mode between architectural and FX simply press and hold both the Program and Option buttons simultaneously for 15 seconds whereupon the lights connected should go from blue to either red or green. Red indicates architectural mode with the FX programs locked out, while green indicates that the FX have been unlocked. This setting is automatically stored in the chips non-volatile memory. You can change between modes at any time by following the same procedure.
There are four colour palletes used:-
Primary. A fixed selection of saturated primary colours.
Vibrant. A stunning range of saturated colours.
Bright. A range of bright saturated and pastel shades.
Full Spectrum. Every colour that can be achieved from black to white.
The programs available:-
1. Morph and hold with vibrant colours. (Hold delay adjustable.)
2. Morph and hold with bright colours. (Hold delay adjustable.)
3. Morph and hold with full spectrum colours. (Hold delay adjustable.)
4. Red marker to help you find your way through the programs.
5. Sweep continually between vibrant colours.
6. Sweep continually between bright colours.
7. Sweep continually between full spectrum colours.
8. Green marker.
9. Indie dim with each colour "rambling" independently.
10. Indie dim pastels (all colours 25% min).
11. Blue marker.
12. Rainbow. Can be stopped and started on any colour using option button.
13. Rainbow continuous. (Speed adjustable)
14. Black marker.
FX routines below can only be accessed when unit is in FX mode.
15. Colour plasma lightning. (Speed adjustable.)
16. White plasma lightning. (Speed adjustable.)
17. Colour strobe. (Speed adjustable.)
18. Magenta marker.
19. Colour burst with vibrant colours. (Speed adjustable.)
20. Colour burst with bright colours. (Speed adjustable.)
21. Colour burst with full spectrum colours. (Speed adjustable.)
22. Cyan marker.
23. Windswept flame effect. (3 independent.) (Speed adjustable.)
24. Subtle flame effect. (3 independent.) (Speed adjustable.)
25. Yellow marker.
26. Static fixed primary colour. (Selectable.)
27. Random fixed full colour. (Reselectable.)
28. Random fixed vibrant colour. (Reselectable.)
29. Ramping fixed primary colour. (Selectable.)
30. Ramping random colour.
31. White marker.
If both program and option buttons are pressed together briefly the unit will revert to program 1.
After any buttons have been pressed the changes will be stored to non volatile memory after a short delay of up to 15 seconds. this will be indicated by a brief blink of the lights and means that the unit will power up in that mode until further changes are made.
