Ring Cyba-Lite (Nuwai) 3C cell: A simple SSC P4 upgrade (lots of pics).
Essexman
U.K.
This torch has three settings 100%, 50% and 25%, and comes with a Lux III as standard, which was a little green. So I decided to upgrade with a SSC P4 star bin USWOI (3.25-3.5V) form Litemania (Available to purchase in the dealers section of this forum).
Firstly I took some measurements for reference;
Lux at 1m
100%=3300
50%=1300
25%=540
Current (measured at LED) [insert pic]
100%=360mA
50%=180mA
25%=82mA
First I had to get inside, easy, it just all unscrews like this
I unsoldered the wires (making a note of which is pos and neg)
Then I pulled the old Lux III off the heatsink
Gave the heatsink a clean, mixed up some two part epoxy with a bit of zinc oxide powder.
Put the glue on the heatsink.
removed star from packet.
and placed on heatsink.
Then I left it to cure.
Once set, re-soldered the wires, and put it all back together.
Then I took some more measurements;
Lux at 1m
100%=7400
50%=4350
25%=1800
100%=412mA
50%=192mA
25%=90mA
I guess the higher current is due to the lower Vf of the emitter, I don't know what the bin of the Lux II was as the original glue pulled off the printing on the back of the star during disassembly.
The results in use are amazing. Nice white colour. Much brighter. Due to the deep reflector this torch throws nice. At a distance the Lux III gave a strong spot with little spill around it. The SSC P4 gives a larger spot with much more usable spill. Close up the SSC P4 gives a small spot, which is a little too bright and intense on full power, but fine at half or quarter power. This was probably due to the dimensional differences between the two emitters. I made no changes to the reflector or the position of the heatsink/emitter.
Compared to my space needle clone (Lux V WWOT direct drive on 6 AA's), the upgraded Ring Cyba-Lite is brighter.
Next time I plan to make a SSC P4 2D Mag........
That's all folks.
Don't get me tempted, I have one of these flashlights.
What I have noticed is that it is very nicely made. Unscrewing the pieces reveals a very nice fit and finish. I especially like the partial orange peel engineered to retain throw, but reduce artifacts.
The one criticism is that it uses PWM for dimmed modes. This gets expecially irritating on low (25%). I assume that this effect is still noticable on the SSC P4.
Beautiful mod, I might just follow in your footsteps.
Mike
Cheers Mike
Yep they are well made. I agree about the reflecter, some thought went into making that.
This was an easy mod, very little cost for double the output with nice white beam.
I've never really noticed the effect of the PWM, I'll have a look tonight.
I should have done some before and after beamshots, if I get time this weekend I'll do some beamshots of the finished upgrade.
Did you manage to get your hands on one of those 3xAAA LED flashlights from Poundland? By my reckoning, it would be possible to make a high-output LED flashlight for less than £5, based on that. My 6 year old brother has been begging me for a Cree/SSC, so I would be very interested in seeing that mod.
Anyway, I would hate to distract from the original point of this thread. Where did you get your SSC P4 stars from? The only places I can find, you have to buy at least a dozen. The Cyba-Lite is no longer safe!!!
Thanks,
Mike
If this light uses Luxeon 3 and claims 80lm as shown here, wouldn't it need close to 1000mA to drive the LED (according to Table 2 )?
Just did my own upgrade.
Checked the amps before the upgrade and it read 850mA/270mA/120mA at the 3 light settings.
Didn't check the new one, but it's VERY bright.
