attowatt
hee hee hee:devil:
attowatt said:Hi chvylvr35O,
Glad to see you signed up. I had tried something similar, by putting a small piece of plastic on the outside of dome, but could not get it to stay. I like your "temp" idea so you can revert to factory mode if need be. Yea once you start sanding, there's no turning back. does that piece of plastic fit snug inside and is it touching the led or not?
Again welcome.
Jim
Darell said:Thanks Jim! I'm happy to report that I *still* don't know if there is any reverse-polarity protection. I'm guessing not, so your help was most welcome! Good catch on the cathode mark of D1.
chvylvr35O said:It fits very snug if you cut it to the proper length and have right diameter source bottle. It doesnt touch the led, it is outside of the metal bars and is only touching the lower globe and inside upper.
Here is a bad pic of it using a pda camera:
attowatt said:Ahh
chvylvr35O,
I like the picture. I am a firm believer in a picture is worth a thousand words. Also like the setup. can you see the effect of the "corragated" sides on the "output" light pattern?
Any chance of getting a "bad pic" with the same setup and the lantern on?
Jim
grayman4hire said:I was at target today and had to buy one. Pretty impressive. Now my fiance can't burn a hole in my tent the next time we go camping.
attowatt said:Thanks for the picture chvylvr35O,
it looks REALLY smooth in that shot. I am really thinking of trying this. How much light is lost, if you had to guesstimate?
Jim
My pda camera really doesn't do well with the light. My good camera will be back by tuesday and I will try it then.Flash_Gordon said:chvylvr35O-
Pretty great idea! We have been trying all types of diffusion techniques here. The best so far is attowatt's dome sanding. It works very well with pretty minimal light loss, but is permanent and a little tricky to do.
What would be great is a picture of your lantern sitting in the same spot with and without the diffuser.
It is cheap, pretty easy and reversible. What tool did you use to cut the bottle?
I am getting a couple more of these lanterns to work on the circuit for a dimming function, but I want to also try your idea.
Mark
zespectre said:Darn it Attowat, now I've gotta go find one of those vials and do that...sheesh, can't you guys leave well enough alone!?!
:laughing:
attowatt said:I re-installed the 20K ohm resistor across R5A and if you DONT look directly at the lantern in "fast strobe" mode, it is acceptable as a poor mans dimmer. When in dim mode, you really cant tell it's strobing, unless you look directly at lantern(if that makes sense). 310mA on high and 80mA on low(dim) using existing batteries( not new).
I will leave it like this until some one try's another board.
Jim
grrickar said:Thanks to all that offered to help. I finally found one at one of our local Target stores (the last one!). The price was only $12.99, at that price I hope that they get some more in soon!
