darknessemitter
- Joined
- May 14, 2008
- Messages
- 202
So on full flood, some have the dark donut hole in the center, and others have a nice center with some dark distortion at the outer edge. But this is a cheap focusing light with some inherent QC variations. So the real question is, on the ones that see a dark center when in full-flood setting, can you find some point, not necessarily at full flood setting, that you can get a decent flood without dark donut hole?
I wonder if different people are just looking at the flood beam differently. I'll try to describe this. Mine doesn't really have a "donut hole," but there is a brighter ring around the outer edge. The center part of the flood beam is the widest part of the beam. It is slightly dimmer than the outermost ring, but the wide center portion is almost as bright and evenly distributed. It works pretty well as a flood unless the slightly brighter outermost ring really bothers you.
The beam is not perfect, but this isn't what I would normally think of as a "donut hole."
