kramer5150
I just got one of these last week...
http://www.dealextreme.com/details.dx/sku.6103
Heres my video review:
http://www.youtube.com/watch?v=tortA0rocjE
And some detailed comments about single handed operation.
http://www.youtube.com/watch?v=c1dkgjkDqAc
WONDERFUL little torch. I love the simplicity of a twist-cap switch. No clickies to foul you up, fail, and leave you in the dark. I have a surefire 6P that is my main light on the job, but the robust switch design of the RC-C3 follows similar suit to the 6P, and is now my best EDC light... by a significant margin.
I find that it works admirably with either RCR123 cell or Primary. On the RCR123 it emits about 90 Lumens, over a 40 minute span. With a Primary it only spits out about 65 Lumens for about 80-90 minutes. So, depending on which cell you choose, you can custom taylor its output. 90 Lumens is nice, but I find that much light can blind the user when used in complete darkness.
Very nice beam quality with a smooth transition from spot to flood. Much better than my other Cree-based lights in this regard. Very good flood quantity too. Color tint is pretty nice too, pretty white overall, and turns yellow as cells deplete.
This light has replaced my Eveready 1AA (Target) and Ray-O-Vac Sportsman Extreme as my main EDC. The fact that it only costs $13 makes it a real winner.
Pros:
-Cheap (very).
-Reliable simplicity if a twist cap, no clicky switch to fail.
-Very good DC-DC regulation.
-Good color tint.
-Durable, I dropped it a couple times on the concrete already and it scratched, but it still works fine.
-Smooth threads and firm O-ring engagements throughout.
-Aluminum reflector + glass lens
-Small & easily pocket-able.
-Splash/rain-proof
-Removable clip
-Tail stands
-Very good beam quality, from spot to flood, perfect for an EDC.
-Runs great with Primaries (65L) even greater on RCR123 (90L).
-You can adjust the head all the way out for lock-out mode, or just slightly rotate it off for momentary forward activation.
-Boxed nice with bubble wrap from Romisen, would make a GREAT gift.
Cons:
-Gets warm fast on RCR123 cell, although temps are much cooler with primary cell.
-Low mode would have been really nice.
-Definitely NOT submersible. I tail-standed mine in about 2 inches of water and after 15 minutes water managed to work its way into the tailcap.
-Anodize coating seems a little fragile.
Pros:
-Cheap (very).
-Good color tint.
-Splash/rain-proof
-Removable clip
-Tail stands
Cons:
