Daekar
So with the recent news and speculation about the possible discontinued production about the Big-D Spotlight bulb sets, I've been wondering about the fate of the manifold ROPs out there. Lets say the bulbs dry up tomorrow... what will you be doing with your ROPs? I'm hoping for an approximately equivalent solution which will drop in - what about a 5761 bulb set in a ceramic bi-pin holder? Should be a little brighter and take about the same voltage, yes? Or do those insta-flash too easily? I really appreciate how easy it was to build my ROP (a gateway light, as some have put it) and how it's "brought hotwires to the masses"... heh heh. Would be nice to keep that going.
Allow me to propose some rough guidelines:
Same BL as ROP +/- 10%
7.2V tolerant
drop-in (as in no driver necessary - bulbs requiring soft-start/drivers aren't drop-in)
So... any ideas?
EDIT: So far, we have...
ROP-Hi:
~ Philips 5761 - 30W, 6V stock rating. Overdriven to 7.2V @ 5+ amps pushes about 250 more lumens vs. ROP-Hi. Current draw makes this less appropriate for cheap batteries. Bi-pin bulb, requires ceramic base.
~ WA1111 - 18.9W, 6V stock rating. Overdriven to 7.2 @ 3.15+ amps pushes about 100-200 lumens less vs. ROP-Hi. Current draw makes this a better choice for cheap batteries. KevinL spectulates that it may be brighter than ROP-Hi was on cheap batts because of lower current drain and less associated voltage sag. Bi-pin bulb, requires ceramic base.
ROP-Lo:
~ WA1165 - 11.22W 6V stock rating. Overdriven to 7.2V @ 1.87+ amps pushes about the same as ROP-Lo (I think). Bi-pin bulb, requires ceramic base.
~ Carley 1057 - 12W 6V stock rating. Overdriven to 7.2V @ 2.00+ amps pushes about 450 BL. Bi-pin bulb, requires ceramic base.
7.2V tolerant
So... any ideas?
ROP-Hi:
ROP-Lo:
