Salt + Raw Aluminum ?
hubbabubba
Doesn't salt corrode raw aluminum? I saw some salt and pepper shakers that are very cool, but they are not anodized.
With solid-on-solid contact, there's infinitely less contact area than if the salt was in a solution. Solids generally don't interact chemically with one another they way liquids and solutions do. I wouldn't worry about the salt corroding the aluminum.
Then the salt will clump and you'll have other problems.
Unless you add some rice to the mixture. The grains will absorb the moisture.
Hey hubbabubba, where did you see these? They are pretty cool. I might get a set.
Aluminum is not soluble in salt water. A lesson often taught with my reef tanks. However, it will attack impurities in various alu alloys.
I'm not too concerned about these S&P shakers.
There's an interesting pdf, regarding the matter.
Here's a quote from it:
Salt water DOES NOT corrode aluminum!
You may have noticed that you never see aluminum
corrosion in lakes, pools, food packaging products, etc.
Typically, if you have seen corroded aluminum, it was in
or near the ocean. While it may seem logical to draw the
conclusion that the salt water must be corrosive to the
aluminum, it is not. Salt water does not corrode aluminum
because of its neutral pH. A saltwater solution can, however,
be a major facilitator for galvanic or dissimilar metal
corrosion, a more complex corrosive process.
Al is actually a reactive metal. It, in fact, almost instantly forms a thin, transparent oxide coating on its surface. This coating is what protects it making it seem resilient.
