C
Curious_character
- Joined
- Nov 10, 2006
- Messages
- 1,211
I have four Sanyo AA 2500 mAh NiMH cells of the latest type -- with the colorful labels. I properly formed them when I first got them, and they have only a few cycles of use. They were normally charged at around 1A with a Maha C9000 charger, and I don't believe I've abused them in any way. I just ran a one-week self discharge test of all the non-low self-discharge cells I have, and discovered that these cells self-discharged by about 25% in one week (temp. ~65 - 70 F), while most of the others averaged around 6%. So if they sit for more than about a week at room temperature, or less than a week at higher temperature, their available capacity is less than a 2000 mAh Eneloop.
I know the early high-capacity NiMH cells developed very high self-discharge rates after a while -- I have quite of few of those -- but I figured they'd fixed the problem. But it appears they haven't. I've converted over nearly entirely to low self-discharge cells, but picked up a pack of the Sanyo 2500s for occasions where I'd be using the cells soon after charging and wanted a little extra capacity. But with the extreme self-discharge rate I'm seeing, I don't consider it worthwhile, and won't be using them.
Are other people seeing this very high self discharge rate for the Sanyo 2500s or other modern cells?
c_c
c_c
