Hay guys,
I wanted to ask you which 12V halogen bulb is the brightest.
I think with my current bulb ( i dont know the name of it anymore ) it throws out over 2000lumen.
( the 12V bulb will be overdriven to 16.8V... )
Yes i read both of them.
I bought a year ago the brightest bulb with this thread.
The problem is that the test doesnt include much 12V - 75W or 100W bulbs...
argh i have a
Osram 64623 HLX 100W
and its the brightest bulb in the test. Im just hoping there is a brighter bulb...
Does it have to be 16.8v? I assume you are either using 4 IMR cells or 14 AA's, either way if youre wanting to keep it in that voltage range then your choices are kind of limited. Me personally I would stay with the 623.
Hay guys,
But remember, it is not all just about the total lumens. A lot of them with the 64623 are "wasted" in so far as they are in such a scattered pattern, I don't consider it an ideal bulb other than its novelty effects.
The problem I see, is that, you are saying 16.8V, but are you talking about 4 li-ion cells fresh off the charger that are reading an open circuit 16.8V or are you talking about a power source that delivers 16.8V under a load?
Assuming 4 li-ion cells, you would actually get less than 5600L, but it would still work pretty decent I suppose.
Assuming 14 high current AA cells. It might theoretically push upwards of 8000 bulb lumens.
I suggest resting the pack at least till it has cooled down after a charge, maybe longer. The re-rating formulas peg the resulting bulb life at ~10 hours at 16.8V, but fresh off the charger it *could* be more than that to the bulb if the cells are really heavy hitters. Below 10 hours of re-rated life is where premature failures really start kicking in.
I have no idea how well that particular bulb mates with reflectors, so best of luck
