ok im going to keep this short and sweet
1st heres how to do it
1) buy a civictor stainless steel, a ssc p4 u bin emitter, aa epoxy, something copper 0.5 - 0.8mm thick
2) open the civictor and remove the pill ( the bit with the led and stuff) any pointed metal thing will work as the head isnt potted (glued in)
3) next you need to get that lux 3 led off - theres a few ways of doing this - i butted the pill against something solid - heated the solder tab for a couple of seconds while sliding a hobby knife under it u need to be quick with the heat if you want to keep the lux led
after that i slid the knife under the led to pop it off
heres what happend for me....
5) do the heat and slid knife under tab thing on the other side
6) scrape all the rubbish off the pill - i dont know how much it matters if you scratch it all up - but i thought - so what - it looked like this...
7) next i decided to thinly apply aa epoxy to the emitter and let it set ( a little differnt to what others have done) mix the epoxy 1:1 and thinly apply with a toothpic or similar...
8) to raise the emitter i used a copper washer 0.5mm thick - the reflector is a little different on this light so a thicker copper slug is pointless.
so i epoxied washer in the space on the pill like so...
9) id let the led epoxy set before i did this - so now i could just stick the led on without worrying about shorting (test the led with a multimeter to check its good to go)
after centering the led best i could very quickly solder the tabs
you will end up with... ( ok i forgot to take a photo of the soldering bit because i was too excited)
let it all dry / set and then wind the pill back in
turn it on
say - why did i bother doin all this!
results were ok but not great
HERES ALL THE BEAM SHOTS
all taken with exposure at -2.0
all lights 0.75m from wall (cream not white)
right - L1P (aprox 30 lumens)
left - civictor modded on LOW
left - civictor modded on MEDIUM
left - civictor modded on HIGH
right - ULTRAFIRE 601 (2aa - looks like a minimag)
any questions just ask - im very happy to help or elaborate on any of it
Alex
turn it on
Alex
