OK, I suck at trying to withhold the truth.
I feel guilty.
I'm sorry for teasing you with the "easter egg".
This is an idea I've had since I was doing ArcAAA LED transplants (I add GID to LED on those). Tvodrd did a quick test and verified that my (new) idea would work, so I decided to do it with my A2:
I crazy-glued 5mm trit vials to the back of the LEDs (one per LED).
Anything bigger would get caught in the bottom of the reflector assembly. I left the glue dry for an entire day to prevent the cyanoacrilate fumes from fogging the insides of the reflector/window. It helps if you have fine-tipped tweezers to do the mod. Glueing two vials would give a lot more glow, but I feel one per LED is enough for my needs (plus, I didn't have vials left).
The glow is much brighter than how it came out in the pics, BTW. I can clearly see my A2 from across my room in the middle of the night. I think it'd work just as well if I'd glued a vial to a single LED. Someone could use 3 different colors, just for kicks. I'm trying to convince carrot that he should do this mod with orange trit. :devil:
I've done a similar mod using GID paint, but the problem is that it only glows
after you turn the light on and the GID charges - it defeats the purpose of using that as an "always on" locator, which is what I wanted this mod to do for me.
Onto a more "electrical" reference on glowing LED's (no joke this time): The Lux on my Arc LS glows for a little while (I have never timed it exactly) after I turn it on.
Again, I'm sorry for teasing you guys like that.
