The P60L LED Module will have a 'peak' output of what SureFire are rating as 80 lumens when used 'momentarily' / briefly. It is normal for SureFire to be conservative with their output ratings. They are not "max" in the sense that if you were to put one in an integrating sphere the maximum output any example would ever achieve is its rated output.
SureFire use the term "max" to indicate that the output changes over time - generally decreases and that within the lumen output ratings SureFire uses for its products it considers the rated output to be the maximum it achieves compared to other SureFire products.
It is not possible to compare lumen output ratings for one manufacture to the next because there is no standardised method for measuring the output and determining the rating.
When SureFire use a lumen rating I consider it to be a realistic expectation of the actual output.
So a 100 lumen rating will indicate that typically the measured output will be at least 100 lumens. In the case of flashlights with 'flat regulation' this output rating will be achieved for the flat regulated runtime.
For lights without flat regulation (including incandescent lights) the output rating is not the peak output but rather the output one might reasonably expect during use as the output decreases. A P60 rated at 65 lumens is actually outputing in the region of 80-100 lumens shortly after fresh batteries are installed constant-on.
The P60L features a temperature sensor that reduces the output as the module heats up in order to prevent overheating. The constant-on output is better described as approximately 65 lumens regulated for 3 hours in the G2, or approximately 75 lumens regulated for 2 hours in the 6P. The output will then decrease considerably for another 9 hours or so of usable light.
There are few who can actually confirm a lumen rating using integrating sphere equipment but many who can perform their own output/runtime charts which in my opinion are significantly more useful than knowing the exact lumen output. I've yet to see any for the G2L or 6PL - has anybody posted one yet?
