SF KL3 head, what reflector would fit??
dutchguy2
the Netherlands and Germany
I have modded my KL3 head with a P7. Since it has an Optic I now have 4 hotspots. (I was more or les expecting this). Now I would like to try a reflector.
What reflector would fit? Inner dimension 32.00mm X 16.00mm or 1.267 inch X 0.632 Inch.
If it is the newer (non-ribber style) an McR27 short will fit with an o-ring around it.
However the beam kinda sucks.
The Ledil EVA might fit too, but you may have to trim the flange a little - but probably not. It is 35mm OD of the flange, but the flange is bigger than it needs to be. The optic itself is only ~26mm at the flange.
$2.10 at Digi-Key last I saw them.
And to help you out, I will take that KL3 optic off your hands if you want to sell it.
Thanks for the tips guys.
I just ordered the Fean reflector.
If the reflector works you can get the optic for free (it isn't mint though)
Cheers,
Jos
If you could trim down a Fraen 34mm MC-E 13.5 degree reflector to fit, that would give you one of the nicest beams available.
:twothumbs Thanks a lot for this advise. I ordered one and it is the perfect reflector for my MOD.
It has the nicest hot spot of all P7 lights I ever saw.
I will go on holiday for a week but after that I will report my mod with pictures and beam shots to show off :D
