Lunarmodule
Eh, howzit! Shoots! Minors, braddah! Get um one da kine Fivemega adapter, garans it work allright lidat, not junks. [end pidgin] :laughing:
Lunarmodule said:Will, I think Luna's correct and it adheres nicely to the KISS principle for running the LOLA. The MN20 (LOLA) is actually a 7.2V lamp that draws 2.45 amps for approximately 17 Watts of output. The MN21 (HOLA) spec is 6.1V with 4.9 amps for about 30W. The common denominator between these two different loads is the right amount of sag with the MB20 holder. I suspect a potential for instaflash with the LOLA with the triple parallel.
Actually, I've been having so much fun with the rechargeable HOLA I havent yet focused on the LOLA application in great detail. Thats a logical next step, go for increased LOLA runtime. I'm receiving some help in regards to a circuit for the pack that limits excessive voltage to guard against instaflash and compatibility with the LOLA. I did instaflash a MN21 when I replaced partially discharged (3.8V) R123s in the MB20 stock holder and THAT was a painful $30 per second mistake so I am a tad leery of killing a LOLA. The LOLA is scarce as all get out until production resumes in Feb/Mar and I gave mine to a friend with another M6 so that solution may have to wait. All dealers I've contacted are out of LOLA stock
TBC
js said:The MN21 is a 6.8 volt lamp on fresh 123's
js said:4.9 to 5.0 amps times 6.8 volts equals 33.3 to 34 watts.
Lunarmodule said:Eh, howzit! Shoots! Minors, braddah! Get um one da kine Fivemega adapter, garans it work allright lidat, not junks. [end pidgin] :laughing:
Luna said:So Brocks measurements are off ?(6.1v 4.9A giving a heated filament resistance of 0.803ohms)
Otherwise wouldn't you be seeing about 5.5A at 6.8V?
js said:Hope that was helpful and not inflamatory. I really don't care to argue about it today.
js said:Oh, and Luna, you should be using the re-rating formulas for determining what the currents and lumens output and lifespan of over or under driven lamps are:
Ir = (Va/Vd)^0.55 * Id
Cr = (Va/Vd)^3.5 * Cd
Lr = (Vd/Va)^12 * Ld
The sub "r" = re-rated, and the sub "d" = design. "L" is life. "C" is mean spherical candlepower, or bulb lumens, and, "I" = current.
Lunarmodule said:As it is I would like to stress I do not believe I am carrying a live grenade with the pin pulled, and I will cease to do so if told by someone (like JS or SilverFox with much more knowledgeability on the specifics of power packs) that even testing with unprot cells is suicidal or too risky...
Luna said:Ok this one I will argue
What is wrong with the ohmic approximation of a filament?
Even though the resistance of the tungsten filament increases over 15 times as it is heated from roomtemperature to 3000K, once at this high temp ,you will have very little change in resistance. Simply stated, i=er would work well in this situation just as it was taught to us in Circuits1 EE course
As for approximating color temp try this:
T = -1.86(R/R0)^2 + 206.6(R/R0) +118
R= resistance of filament at temp
R0=roomtemp(0 really but no need to freeze it)
js said:The problem with an ohmic approximation is that it is wrong.
Period.
You need to use the re-rating formulas. But I disdain to argue with you on this one. Do whatever makes you happy. Just note that I disagree with you, and that I agree to disagree.
