De-Lux
I just received my Eiger wide #3 (No optic) in keychain style body. Awesome light. I came up with a simple way to add a bit grip to the body using Polyolefin heat shrink tubing. It worked pretty well so I figured that I would share with the rest of the group.
1/2" Polyolefin heat shrink tubing from local hardware store.
Finished product after applying the heat shrink tubing. Simply remove the head and battery then slide the tubing over the body. I then used a standard bic lighter to heat the tubing ( keep flame moving to prevent melting). I then trimmed the excess. Replace battery and head and that's it.
Gives it a bit more of a tactical look.
Peak Eiger with diffuser. The diffuser is a must have in my opinion. The diffuser also fits perfectly over the momentary tail switch to keep switch from activating while in your pocket.
Peak Eiger wide (older optic) with 10180 lug body next to Eiger wide (Newer optic) keychain style body with momentary tail switch.
