Re: simple high/low drop-in for Arc LS / L4
The resistor is in series with the electronics. It forces it out of regulation. The resistor drops the current to about 30ma, depending on the resistance of the circuitry and LED. Assuming 1300 mah in a CR123a, that's 43 hours at 30ma. As the battery voltage drops, so does the current and the LED light level.
I've run mine for 24 hours straight. I posted about it somewhere in this thread. /ubbthreads/images/graemlins/smile.gif I started with a battery that was used for a while, then turned it on and left it on. At 12 hours I stopped the test to see if it would still enter Sun-mode. Yup, it did. It started to dim after 16 hours or so, but was still usable at 24 hours. It came back to a nice bright 'moon mode' when I put it in high beam after 24 hours.
I'm guessing that I can get about 30 - 40 hours of moon mode IF I don't use sun-mode and start with fresh batteries. I figure that mine's mostly in moon mode, and I use it for 5 to 10 minutes a day. I'll have to replace the battery sometime in March to assure that I have Sun-mode when I want it. If I just use it till it dims out I'll be replacing the battery in June or July.
I'm sure the ARC4 will do even better simply because it uses PWM for dimming instead of resistance. It will also step down to the next level when the battery can no longer handle the currnt required for the current level.
Daniel
