Thanks very much NoBones.
Now for my 1st question - AND PLEASE VINH - if you would rather not have this kind of discussion in this thread just let me know where to ask. Easy enough to move to another thread or start a new one. I'm sure I'm not the only person wondering how to get the best from your
Sky Lumen BABY. This thread is fine.
As a THROWER? My 1st inclination is to think this SLN would make a great night time spotter light out in the woods - maybe with an auxiliary red lens. So the question is - Will this make a decent thrower spotting light? How big a beam might there be a 20', for example? Would I get a 12" dia. spot at that distance or 6"? Bigger spot at greater distance even better!!!
I read this in another thread - "Yes the less the beam spreads the more light can be put further down target. That's why lasers can throw so long." If that's the case would the beam be pencil thin and the spot not much bigger? I have a TN32 that Vinh has modded for my current thrower. It works beautifully from my back porch but is a bit large for lugging on walks.
If the answer is YES - SLN could be a great little thrower - then the question is - what LED(s)(true to color rendition) & reflector would optimize this use?
I haven't decide that a thrower is what I want. Most often I'm partial to lighting up the scene in front of me - big spread, true colors, 4 or 5 brightness options. BUT - the little thrower concept could make a very fun and useful light and so I ask.
Thanks for any suggestions.
Sam
It seems you do not want a dedicated thrower with a tight hot spot so I would not recommend W1.1 or W2.
SST40 HD 5000K with a smooth reflector is what I would recommend. Seems to to be the higher output, larger hot spot, with a neutral tint that you are after.
