Re: SkyRC — IFA 2014 / CES 2016 — MC3000 charger-analyzer
Albert, sorry you still don't have your MC3000. Where do you live? To answer your questions, read the first paragraph on page 16 of the MC3000 Manual. The unit has six temperature sensors, two are on the Heatsink and the others are on each of the four slots. The results can be displayed in ℉ or ℃. I haven't felt any need to measure battery temperature with my Laser Temperature Gauge. The batteries have always been cool to the touch. The battery temperature seldom gets to as high as 100℉.
From user's manual.
SysTemp→ #1,#2 → #3,#4 → ...
Shows the temperature as recorded by temperature sensors placed right at the internal aluminum cooler and as reported by the 4 sensors at the slots. Note that these are correct values at the sensors themselves and cannot be precisely the spatial temperature average of the targets of interest. Since it is practically impossible to isolate thermal paths in a compact 4-bay charger, heat may reach the different sensors from various directions and sources, hence actual battery temperature will be higher or lower than indicated, depending on the complex charging and the environmental situation.
_________
Temp Unit
Lets the user choose the preferred temperature unit to be displayed in GSV, SPV, SOV, and elsewhere.
_____
BattTemp
Shows the battery temperature, or to be more precise, the slot temperature. Same value as seen in GSV, it mostly serves as safety feature for battery overheat protection. To change the temperature unit, go to GSV and change Temp Unit. Note that physically, temperature is a scalar field quantity, i.e. any point on the battery surface will have a different temperature and depending on the charging situation and your environment, the extreme temperature points on your battery may be notably cooler or warmer than the single value given here.
_____________
SysTemp
Shows the internal system temperature. Same value as seen in GSV, it serves as safety feature for device overheat protection. At full load it can go as high as 80°C or higher and will shut down operation thereabout. The cooling fan is controlled by this value.
________
TOV = total overview
IMV = info message view in TOV
UCV = user calibration view in TOV
SOV = slot operation view
SPV = slot programming view
GSV = global setup view
DDV = diagram drawing view
Apparently the "Operating Temperature" specification is a min. & max. ambient room temperature range.
Battery Temperature: 20°C ~ 70°C safety cut-off (+ safety net) (68 deg. F ~ 158 deg F.)
Internal Temperature: 85°C safety net (185 deg. F)
Operating Temperature: 0°C ~ 40°C ventilated room (32 deg. F ~ 104 deg. F)
