SL TL-2(3w Luxeon)
DoubleDutch
The Netherlands - one foot below sea level
Dukester,
The 2nd generation TL2 Luxeon is regulated. I don't own one, but my guess is that 2xRCR123's will damage the electronics (may go as high as 8.4V). Pila 168s will do fine, but with 20% reduced output, according to Quickbeam's excellent site (FlashlightReviews.com).
Kees
PJD
NW FL
Dukester...if I'm not mistaken, both the old and new generation of the SL TL-2 LED are 1 watters, not LuxIII.
PJD
Dukester
Washington State
[ QUOTE ]
PJD
[/ QUOTE ]
Actually PJD, you may be thinking of another light. This is the light I am referring to and it is a 3w LuX.
Task-Light™ 2L3W
Versatile, durable, with exceptional brightness and long run time.
• Powered by two 3 volt CR123A lithium batteries with a shelf life of nearly 10 years (included)
• 3 watt Luxeon® Star, super high-flux LED with 20,000-hour life
• Up to 77 lumens typical – 20 times brighter than a high-intensity LED
• High (100%): Runs 3 hrs, at High (100%): regulated maximum intensity plus 1.5+ hrs. of declining usable light
• Low (25%): 9+ hrs.
• 1.33" (D) x 6.12" (L)
• 6 oz. with batteries
• Available in matte black
You can read about the light here... http://www.streamlight.com/tl2l3w.htm
The light was introduced I believe last Winter.
dano
East Bay, Cali.
The real TL-2 is a 1 watter. The TaskLight 2L3W is a 3watter, and somewhat of an odd Streamlight; it isn't too popular, but should be.
--dan
Dukester
Washington State
[ QUOTE ]
--dan
[/ QUOTE ]
Yes dano, you are correct and I do stand corrected. I have always liked this torch since I bought it last winter. The throw on it is pretty remarkable and I would like this light even more if it could handle RCR123's.
Dave
Bullzeyebill
CA
Because this light is being run with two Cr123's, starting out at 6.5 volts (3.25volts each), it probably utilizes a buck circuit, and may tolerate higher voltage. I am not sure if the circuit can handle 8.4 volts, but maybe someone has the answer.
Bill
Pwdrkeg
NJ
I use the Pila 168s Rechargeable Li-ion in mine,
it works just fine.
..... /ubbthreads/images/graemlins/happy23.gif
Dukester
Washington State
[ QUOTE ]
it works just fine.
[/ QUOTE ]
Pwdrkeg What's the voltage rating on your 168's? I suppose I could go ahead and look it up.
Thanks,
Dave
Pwdrkeg
NJ
[ QUOTE ]
Thanks,
Dave
[/ QUOTE ]
Dave,
They are the same size as two CR123 lithium batteries and
are rated at 1400 mAh & 3.7v each. I believe they produce
a little over 4v fresh off the charger and seem to work very
well in the SL 2L.
PJD
NW FL
[ QUOTE ]
Dukester said:
[ QUOTE ]
PJD
[/ QUOTE ]
Task-Light™ 2L3W
[/ QUOTE ]
Okay, I see! You're talking about the 2L 3W luxeon task light with 2 brightness settings. My bad...I thought you were referring to the new version TL-2 LED.
PJD
Dukester
Washington State
[ QUOTE ]
Pwdrkeg said:
[ QUOTE ]
Thanks,
Dave
[/ QUOTE ]
Dave,
well in the SL 2L.
[/ QUOTE ]
Pwdrkeg Thanks a lot for the info. I ordered a Li-Ion Charger plus 4 RCR123 Batteries and the TaskLight 2L3W will be one of the lights I will use them in. Dano hit it on the head, this light is a hidden wonder in my opinion, has descent throw and output.
vhyper007
32*31\'N 92*11\'W
Pwdrkeg,
neat avatar. At first glance I thought it was a tree that someone had set ablaze by illuminating with a megaray. No shortage of adrenalin in your life is there?
Be safe,
vhyper
nemul
Georgia
i have both, TL-2 and 2L3W. look about the same in output to me .. never used RCR123A, sorry...
but i've upgraded my TL-2 to a LuxIII white and im waiting for my LuxIII R/O 190 lumens in the mail for my 2L3W
